07-17-2022
10:51
11:54
07-17-2022
10:51
11:54
Hi.. my versa 2 display has problem..some hazy colour lines appear often on borders n rest of screen is black..it gets charged ..it syncs with mobile app and steps get updated but can’t see anything on display.. screen not broken or no physical damage..çan someone help how it fix it
thank u
Hi there, @arjun9. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 2.
As @Guy_ has recommended, please restart your Versa 2 as suggested here How do I restart my Fitbit device? If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Hope that helps.
Hi @arjun9 - as the watch is working fine, check the following
Hope that helps.
Best AnswerThis didn't work for me. I am having the exact same issue. Are there any other work arounds to getting the display to work again?
Thank you!
Best AnswerI had the same problem. I restarted it several times, recharged it, changed the face, nothing worked. It finally went dead and not recharging. Wishing you better luck but I feel that as soon as they update firmware the older models go dead. Look at the numbers of post about a blank screen.
