07-22-2020
03:39
10:41
DavideFitbit
07-22-2020
03:39
10:41
DavideFitbit
The screen aint working and if the screen stsrts working the touch doesnt work. It doesnt connect or sync with my phone at all
07-22-2020 03:46
07-22-2020 03:46
Hi @Sush012 Try restarting your Versa 2 several times. Also try a Factory Reset. If they dont help you then contact Support.
BUTTON FACTORY RESET FOR VERSA 2 AND VERSA LITE
Hold the back button for about 8 seconds.
When the Fitbit logo disappears: Release the button briefly (for less than 2 seconds).
Hold the button again until you feel a second, longer vibration, which indicates the factory reset.
Helen | Western Australia
07-22-2020 05:18
07-22-2020 05:18
Where is the button on the back?
Best Answer07-22-2020 05:35
07-22-2020 05:35
There isnt a button on the back. They mean the button on the left side which takes you back to the home screen (the clock) so is called the 'back' button.
