09-09-2020
19:42
14:38
09-09-2020
19:42
14:38
Tonight my Versa 2 screen started going all wierd with lines and dots across the entire screen, almost completely whiting the screen out, like there's a short in the internal wiring or something. I checked for cracks, any reason for it, don't see anything and I was just sitting on the couch when it started doing this. I did a shutdown, it went back to normal, all functions and screen worked again, but after moving my wrist the screen started going wierd again. I've had it less than a year, how do I get this fixed?
Hi there @Ltlitaly, welcome on board. I'm sorry to hear about your Versa 2's recent behavior. I appreciate your time and efforts in troubleshooting your watch prior to posting here.
I've seen you got in touch with our Support Team after posting here and they have already helping you to get back on track.
Hello there @CaroJane and @Lmilla, welcome on board. I'm sorry to hear that your watches are also having this behavior. Thanks for trying to solve the inconvenience.
In order for me to better assist you, please confirm that you've followed the steps below:
Best AnswerThanks for the feedback. I've have both restarted the watch and changed the watch face without success. Next steps please. thnx
Best AnswerHas anyone gotten back to you? I have also tried everything I can Think of and it’s still goofy. It was fine at night, woke up and my phone had done an update and my watch was all wrong. I am getting annoyed to say the least.
Best AnswerHello,
my versa 2 has the same problem. It seems that the problem started after I updated to the last firmware. I tried to solve the problem:
1. Restart the watch: settings->about->shut down & start over. - the problem doesn't go away.
2. Did 2 factory reset with no effect.
I don't know what to do.
Please help!
Ciprian
Yes, I was lucky and my Versa 2 was still under warranty. They didn't even question the issues it was having really, other than asking if I had tried all the shutdown and restart stuff already. They are sending me a new one. I checked it today and it's still doing the same thing so my guess is mine had a short somewhere. I'm just hoping it doesn't happen with the new one too. It's alot of money to spend on something that goes out in under a year.
Thanks for your reply... I have both tried to change the clock face and restarted my versa. The screen is still having the same issues.
Best AnswerHi Farmworker yes, I followed the steps to reboot etc to no avail. Thankfully, my Versa 2 is also still under warranty so fitbit very quickly decided to send me a new one for which I am very grateful as I really love my versa 2. The watch itself is still working although the purple screen is slowly getting bigger and sometimes I have to tap twice to get a reaction. To be clear, some of the problems mentioned here are different but my issue was quite specific. Please see photo..
Best AnswerDitto here on my end. tried all the recommended fixes and no luck Just started today. Not happy.
Best AnswerHi PerturbedPatty, I recommend you to get in touch with the support desk directly. This is clearly a common problem and they were extremely helpful in my case, Good luck
