Versa 2 screen is acting odd
ANSWERED
My versa 2 screen has started glitching a lot ! I’ve restarted it a few times and it seems ok for a few hours before returning, it flashes white lines across the screen until it’s unreadable. Help it’s driving me crazy.
1 BEST ANSWER
Accepted Solutions
Hi there, @SarahBarling197. Thanks for stopping by in the Community Forums and trying to troubleshoot the issue with your Versa 2 before reaching out.
To better assist you, please make sure you've restarted your Fitbit device as suggested here How do I restart my Fitbit device?. If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
@Guy_ Thank you so much for your input!
2 REPLIES 2
Hi @SarahBarling197 - if it's still under warranty, 1 - 2 years depending on country it can be replaced where you bought it.
