01-08-2023
09:43
02:51
01-08-2023
09:43
02:51
On my versa 2, the clock face overlapping. Tried to reset the watch multiple times but couldn't help.
Please suggest
Hi there, @chetangawande. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out and the image attached.
To better assist you, please make sure you've restarted your Fitbit device as suggested here How do I restart my Fitbit device?. If the restart doesn't work, as @Guy_ has suggested, try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Hi @chetangawande - it may be burn in from another clock face, that had Always On enabled but try changing clock face and see if it helps.
If when you swipe the watch face left and the problem remains it is burn in.
