09-21-2019 20:51
09-21-2019 20:51
I've only had my Versa 2 for a day and the screen has went green and fuzzy. Can still see the clock but when I push the button it goes gray and fuzzy with a line the moves top to bottom. Tried restarting it, work for about five minutes then went back to being fuzzy and not working.
09-22-2019 01:50
09-22-2019 01:50
The restart is the only real tool that we have to address problems. If that's not working for you then it doesn't sound good.
Are you able to exchange it through your retailer? If not, you should be covered by the fitbit warranty so it's worth contacting them. If they can't fix it they can check your warranty and advise on your options: contact.fitbit.com
Best Answer09-22-2019 02:02
09-22-2019 02:02
Hi @Chella2011, welcome to the community.
Have you tried changing the clock face to see if that fixes things?
Best Answer01-09-2020 18:44
01-09-2020 18:44
Was this ever resolved? I have the same issue.
Best Answer01-09-2020 21:05
01-09-2020 21:05
