03-11-2025
14:27
06:22
03-11-2025
14:27
06:22
My screen is non responsive to touch. the side button still works and i can select an exercise but can't finish it or anything. Have pressed the side button about a hundred times and rebooted it with no joy... Uninstalled it from the app twice and re paired it.. still the same. Changed a clock face... still the same.
is there any other way to do a factory reset other than on the watch face which I can't access?
03-11-2025 21:07
03-11-2025 21:07
Hi @LisabDotie - unfortunately symptoms such as touch/swipe failure usually indicate watch damage, possibly from water or excessive sweat, but if the watch is charging and working normally otherwise it could possibly be a software fault.
Support can help you with a factory reset using the button. It can be tricky and if it fails the watch can no longer be used. Also if you live in the EEA you will only be able to reinstall Fitbit stuff.
It is a good idea to make a note of the names of any clocks or apps and any special watch or app settings you use before the factory reset or replacement if necessary, to help with reinstalling.
03-12-2025 06:27
03-12-2025 06:27
Hi there, @LisabDotie. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Versa 2 is still unresponsive. @Guy_ Thank you so much for your help!
I've seen you contacted our Support Team just right after posting here and they've already assisted you. If you have any questions regarding the outcome of your case, please don't hesitate to reach out to our team again. Since you already have a ticket open with them it'd be easier to continue the follow up on this matter with them directly.
Thanks in advance!
