08-05-2021
08:56
10:03
JuanJoFitbit
08-05-2021
08:56
10:03
JuanJoFitbit
I cannot swipe on my Versa 2 as of yesterday. I have worked with two different support agents and both want me to factory reset. I cannot swipe off the face clock to get to the Settings App to do it. Is there another solution to factory reset that doesn't require swiping? I have also tried soft restarts which do not yield any different results.
@melchiefs It's great to see you in our Fitbit Community. I totally understand how you feel about the swiping issue that the screen of your Versa 2 has experienced. By the way, thank you for trying to get this issue resolved before contacting our forums.
Please try another way to perform a factory reset. To do so, follow the steps below:
After this, monitor your watch and see if it works properly.
Hope this helps.
Best AnswerI have tried to do this numerous times. As soon as the FitBit logo disappears, the clock face reappears. There is no lag to do to the release the button briefly.
As of yesterday I am having same issue. Can’t swipe and even when Lock Screen comes up I can’t put in my pin. I have tried reset process multiple times and still doesn’t allow me to swipe screen and go to settings and apps etc.
Yes! I cannot swipe to the timer, alarm, exercise, anything! My last update through App Store was 7/27/2021 so it doesn't time perfectly with the update.
I have the same issue. Touch screen got glitchy a few days ago, now I am unable to swipe at all. I just spent an hour with three different support people on live chat. Tried everything: changing clock face, restart, turning Bluetooth off and on, deleting and reinstalling the app- removing and re-adding the device. This is my second Versa , and once again they are offering a discount because it is out of warranty. No thanks- I will not be purchasing another Fitbit product EVER. A little over a year of use is unacceptable.
I have just started to have this issue! I don’t want a new watch either, I just want mine to work as it says it is going to 😢. I am thinking I should have better invested in an Apple Watch 😭
08-07-2021
16:48
04:13
JuanJoFitbit
08-07-2021
16:48
04:13
JuanJoFitbit
I was thinking the same thing. For how much I have spent on the last two Versas, I could have almost bought an Apple Watch!
The factory reset totally messed mine up. It Keeps saying “unable to clear , sync again “ I can’t sink and it keeps telling me to disconnect it from Bluetooth and re-pair. Can’t do that either. At least before the factory reset I was able to see steps and the time. Now it’s useless.
Moderator edit: merged reply
My versa 2 is also doing this, I have tried the above suggestions but it does nothing, I only got it last Christmas! What else can be done? I can't even turn my alarms off and they're driving me mad
