12-18-2021
18:01
04:21
12-18-2021
18:01
04:21
Versa 2 screen brightness is too dim. With low it's almost black, barely visible with normal and even with max cannot see some small text on screen.
Before this, I had the lines problem in the screen, and the touch screen not working
How can I correct this weird behaviour?
Hi @BrunoOlivera - you may be in Sleep mode, pull down from the top of the screen as if to see notifications, pull down again and click on the 2 white bars to get to Quick Settings and disable Sleep [and do not disturb perhaps]. This should restore your brightness.
Hi there, @BrunoOlivera. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 2. I understand where your concern is coming from.
Have you checked if the brightness has been set correctly? To do so, swipe down from the top of your screen. After your notifications appear, swipe down again to open the control center. Tap the brightness setting icon.
If the above doesn't work, please check if your Versa 2 isn't in sleep mode. When you turn on the sleep mode setting:
For more information, see How do I navigate my Fitbit device?
Hope that helps.
@BrunoOlivera I appreciate you had followed the tips and recommendations provided above.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
