05-30-2022
14:02
17:52
LizzyFitbit
05-30-2022
14:02
17:52
LizzyFitbit
My screen all of a sudden went black and I cannot get it to come by on. How to restart?
Moderator Edit: Clarified subject and updated label
05-30-2022 15:48
05-30-2022 15:48
Hello @echunt
You asked how to restart your Fitbit …you didn’t mention which Fitbit you have but no worries. Look here to see how it’s properly done with your particular Fitbit: https://help.fitbit.com/articles/en_US/Help_article/1186.htm
😉 please let me know if this was what you were looking for
05-30-2022 17:55
05-30-2022 17:55
Welcome to the Community, @echunt. @SunsetRunner Thanks for your great help.
@echunt I've moved your post to the Other Versa Smartwatches as there are more chances to get related replies here. Thanks for letting us know about your watch. If you haven't done so, please give a try to the steps suggested by @SunsetRunner and monitor its behavior in the next days.
06-05-2022 15:40
06-05-2022 15:40
Currently, the only thing I get on the Fitbit Versa 2 is the Fitbit logo. I have charged it for days but I can see nothing but the logo. It has been very frustrating. When this started it was a continuous vibrate that could not be stopped.
06-05-2022 15:43
06-05-2022 15:43
I did try everything from @SunsetRunner but nothing has helped. The logo continues to be the only thing on the Fitbit watch screen.
06-05-2022 16:40 - edited 06-05-2022 16:40
Hello again @echunt
I see you have tried restarting your. Versa 2 but it appears to remain on the Fitbit Logo still. When your Fitbit shows just the logo on-screen, it could indicate a problem loading your clock face. Try changing your clock face.
Hopefully this works …keep me posted
06-06-2022 14:35
06-06-2022 14:35
Hi there, @echunt. @SunsetRunner Thanks for stopping by to help our member.
@echunt Thanks for restarting your watch, and sharing more details about this issue. As our friend mentioned, it might be an issue with the clock face. However, I'm also concerned about the connection between your watch and the Fitbit app. For this reason, I'd recommend trying these steps and once that is completed, follow the steps suggested by @SunsetRunner.
Best Answer06-07-2022 12:18
06-07-2022 12:18
I have the exact same problem !! Nothing I have tried works, I have tried everything that was suggested. I think it may be a software issue ??? I noticed many others on here complaining about the same thing !!
Best Answer06-07-2022 12:21
06-07-2022 12:21
@bevgrundvig Did you try to set it up as a new device as the moderator @LizzyFitbit here suggested?
Best Answer06-07-2022 12:23
06-07-2022 12:23
I really don’t think it’s a software issue @bevgrundvig. I have a Versa 2 as well and mine is functioning properly.
Best Answer06-07-2022 13:28
06-07-2022 13:28
@bevgrundvig Maybe you need to contact Fitbit Customer Service: https://myhelp.fitbit.com/s/support?language=en_US No one here can possibly help you if you keep jumping from thread to thread here (currently 12 times in the past hour) stating the same thing. It certainly doesn’t get your issue addressed any faster
06-07-2022 13:43
06-07-2022 13:43
Best Answer06-07-2022 14:54 - edited 06-07-2022 14:55
Hello again @bevgrundvig
I understand your frustration as I would be frustrated as well I promise you. I understand your having issues with the Fitbit Logo flashing on your Versa 2. I see that you think it’s possible that it might be a software update issue but it’s hard to tell especially since I have a Versa 2 also and have the latest update on my Fitbit as well as the Fitbit App and I’m personally not experiencing any issues so I can’t say it’s a software update issue with 100% certainty. I’m sure you can understand where I’m coming from as well. I think we need to first check to see if your mobile device is compatible: https://www.fitbit.com/global/us/technology/compatible-devices If it is compatible can you please make sure your mobile device as well as your Fitbit App is also up to date. The latest iOS update is Version 3.60 make sure your is that as well. If all is updated please try restarting your Versa 2:https://help.fitbit.com/articles/en_US/Help_article/1186.htm If a restart doesn’t help you should at least try it two more times. Sometimes once is not enough. If the problem persist go to the Bluetooth list on your mobile device and find your Versa 2 on the list. Tap the information blue icon next to Versa 2 on the list then tap forget device. Now log out of the Fitbit App then force shut the Fitbit App by swiping the App upward. Place your Versa 2 in its charger. Now restart your phone then log back into the Fitbit App as you normally would. Now tap your profile picture then scroll down and tap Set Up A Device. Chose Versa 2 in the list of fitbit then just follow the onscreen instructions.
😃Please take the time to try these steps and tell me how it goes.
Best Answer06-07-2022 16:21
06-07-2022 16:21
16:30
18:12
LizzyFitbit
06-07-2022
16:30
18:12
LizzyFitbit
This was my last replacement, It's just a little over a year old 😪
| Here's what we shipped: |
Moderator Edit: Personal info removed
06-07-2022 16:44 - edited 06-07-2022 16:45
I’m sorry all this has happened to you. I really enjoy my Fitbit so I can understand the commitment to try to keep it running and can certainly sympathize with the cost of replacing it for a new watch because right now money is tough on everyone. I didn’t see you mention how it went trying to set up your Versa 2 as a new device as I described in my last post. Maybe you’ve reached your wits end and decided enough is enough I suppose. But with that said I see you have decided to purchase a New Fitbit Luxe. I do hope it arrives soon…you love it…and get some Happy Stepping with it!
😃I do hope you enjoy the rest of your evening and hopefully you’ll be back up and running again soon!
on another quick note… I love your profile picture. Pugs are my absolute favorite!!!
Best Answer06-08-2022 16:42
06-08-2022 16:42
06-08-2022 16:47
06-08-2022 16:47
06-09-2022 07:58
06-09-2022 07:58
This was helpful. My screen kept flashing and I changed the clock face and it helped. Thank you
06-09-2022 09:06
06-09-2022 09:06
That’s fantastic news @JusBeanz ! 😃 I’m happy to see this helped fix your issue. Enjoy the rest of your day and Happy Stepping!
