06-21-2025
13:01
19:05
ManuFitbit
06-21-2025
13:01
19:05
ManuFitbit
The Versa 2 screen is just a bunch of horizontal grey lines. The Versa 2 is unresponsive to any attempt to restart, update or sync etc.
Moderator edit: clarified subject.
06-21-2025 19:02 - edited 06-21-2025 19:02
Hi @Mcalder77. Welcome to the forums.
Thank you for sharing with me the information regarding this difficulty that you are experiencing with Versa 2. Thank you for trying to fix it on your own.
Please, try the following troubleshooting steps:
Sync the device in the Fitbit app:
If this doesn’t work, proceed to restart the device. Your data won't be deleted.
If you are still having the same issue, change your clock face: How do I change the clock face on my Fitbit device?. If this fixes the issue, you can change your clock face back to the original.
