10-18-2022
07:42
10:18
AndreaFitbit
10-18-2022
07:42
10:18
AndreaFitbit
Fitbit versa 2 main screen face won’t come on. If I push the side button nothing happens, if I hold side button daily events drag down comes up. I can pull the screen to either side but the main tracking face is gone. Was perfectly fine yesterday. When I took it off charger had it on my wrist for about five minutes and it’s charge went down 5%? It usually takes all day for that to happen. It also won’t sync to my app. I don’t think I even got the update, it just stopped altogether.
10-18-2022 09:12
10-18-2022 09:12
So if you hold in the side button for an extended time, it does not reboot? Usually if you hold it in it will go to a blank screen then back to the Fitbit logo which is when you should release the button.
