02-10-2023
05:00
07:08
02-10-2023
05:00
07:08
Although other posts say problem is fixed i still do not get full data report. Limited to calories and 3 other No sleep info, no steps. Have reset Versa as well as shut down and restart iPad
HI @FloridaDasher - the problem should be fixed but measures you took previously may have an impact.
Best is to limit to the watch and iPad
Logout of the Fitbit App and swipe the active window off, clear the storage cache and force stop it.
Restart both watch and iPad
Login to the app and click Edit to adjust any missing elements and then Done and sync.
02-10-2023
07:38
07:17
02-10-2023
07:38
07:17
Did Log out and restart both but
i have no idea how to clear cache or what is meant by “force stop it”
Moderator Edit: Formatting
@FloridaDasher- I should have been more clear, don't think the iPad has that option, only Android.
Did the restarts work? See also Why won't my Fitbit device sync?
