08-10-2020
07:08
12:57
08-10-2020
07:08
12:57
Hello ! For the past couple of weeks my Versa 2 has been giving me problems - first it was the screen which went black with flickering and now recently it's not syncing with my phone plus it shows device not found . Been to your help section and did all the steps mentioned by you - uninstalled the app , deleted the account , switched off and on the mobile but still the problem persist .
08-11-2020 13:05 - edited 02-18-2024 04:54
Hi there @AjDoon, welcome to the Community Forums. Thanks for the details provided in your post about the syncing and screen issues you've been recently having with your Versa 2. I appreciate you took the time to troubleshoot the syncing issue prior to posting here.
In order for me to better assist you, would you mind confirming that you've followed the steps provided in this help article: Why won't my Fitbit device sync?
Also, if you haven't done so yet, I'd recommend taking a look at: Which phones and tablets can I use with my Fitbit watch or tracker?
Best Answer08-13-2020 08:12
08-13-2020 08:12
Best Answer08-13-2020 10:54 - edited 10-03-2023 17:27
Hi there @AjDoon, thanks for getting back and for the update. I appreciate you've taken the time to follow the tips and recommendations I provided. Since none of the steps you tried have worked, I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you as soon as possible since our support options are limited and wait times are longer than usual.
