03-27-2023 17:44 - last edited on 03-28-2023 07:49 by MarreFitbit
I got in the pool with my Versa 2 and the screen went black as soon as it made contact with the water. I let it sit for about 48 hours and then tried to charge it but it will not come on. Is there anything I can do?
03-28-2023 07:52 - edited 06-17-2023 10:46
Hi there, @Absentia. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Versa 2.
If your watch got wet, it’s important to take it off and dry it well before putting it back on. If your watch has come into contact with any liquid other than fresh water, you should clean it with fresh water and a soap-free cleanser (like Cetaphil) and dry it with a lint free-cloth. Be sure to follow our Wear and Care instructions to keep your device clean.
Water resistance may diminish over time and can be negatively impacted by any of the following:
If your watch is still not responding after taking the above into consideration, as @Guy_ has suggested, the best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
03-27-2023 23:14
03-27-2023 23:14
Hi @Absentia - - it should be noted that the watch seals are not always very robust and also degrade over time. If you swim, get the watch wet or even sweat a lot, water can get in and cause the watch battery to drain very quickly and get hot when charging, if it does stop immediately.
You can try drying in a bag of rice for a few days but generally if it turned off the damage has been done and even if it does recover it may not work properly, so most likely needs replacing.
It can be replaced free if it is under warranty
If no longer covered try getting another Versa 2 which will be fully compatible as later Fitbit watches are more expensive and may not have the same features as your current watch. Also note the names of any clocks or apps you use in the Gallery tile for easy reinstallation if necessary, or research other brands too
06-18-2023 16:42
06-18-2023 16:42
Fitbits are promoted as being able to be worn swimming to 50m- if there’s problems
with every Fitbit worn in the pool maybe shouldn’t promote them as pool adept
