02-21-2022
06:43
04:39
02-21-2022
06:43
04:39
I've tried holding in the button until the logo disappears, & again after 2 second to try to restart it. But get no restart, no vibration, no green lights on the back, nothing. I've tried syncing without luck; running the battery down & recharging and then syncing, still nothing. Is there any hope for this thing? I really loved it until this happened!
Hi there, @Lissylady. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out.
In addition to the steps you've done so far, please try the ones below:
If you can't get started with your Versa 2, usually a missing requirement is the cause. Carefully review the requirements provided in the help article: Why can't I set up my Fitbit device?
Hope that helps.
Hope that helps.
Hi there, @AndyBMCFC. Welcome to the Community Forums.
The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
Hi! I tried everything you suggested. I was able to get it off the fitbit logo for about 2 hours, then it went back to the logo. It would not do a full setup though, it won't swipe anymore, so I couldn't finish setting up the shortcuts, and now it won't swipe to get anywhere but the clock. I've removed it from my account and reloaded it 3 times, without luck on getting it setup and working like it was.
@Lissylady I appreciate you had followed the tips and recommendations provided above.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
