11-13-2022
18:29
14:25
11-13-2022
18:29
14:25
My watch was working fine then I moved my wrist and saw that it was making the Fitbit symbol so I plugged it in and it’s still making the symbol I also tried to reset it by holding the button down
Hi there, @MyrandaRoche. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out.
Please note the issue you're having comes from performing a factory reset without first unpairing your Fitbit device from your Fitbit account and phone's Bluetooth settings. With that being said, I suggest following the steps below in the order listed:
If you can't get started with your Versa 2, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
If you continue having issues updating your Fitbit device, see Why can't I update my Fitbit device?
