12-21-2020
08:53
12:16
12-21-2020
08:53
12:16
Hello, my versa 2 wont update the latest firmware. It is displaying the fitbit logo only can not get it to reset or do anything other than show the logo.
Hi there @DIVERDUDE2012, welcome to the Community Forums. Thanks for sharing the details about the issue with your Versa 2 and for trying to troubleshoot it before reaching out.
If you haven't done so yet, please try the following steps:
If you can't get started with your Versa 2, usually a missing requirement is the cause. Carefully review the requirements provided in the help article: Why can't I set up my Fitbit device?
Let me know how it goes.
I have the exact same issue of a flashing logo. This started yesterday morning. My Versa 2 has been operating fine for 11 months. Now it’s unusable. It won’t respond to resets, plugging into charger, etc. I’d really appreciate any guidance.
@DIVERDUDE2012 and @VicRice (welcome on board!) I appreciate you had followed the tips and recommendations provided above. Since this sounds a bit more serious, I've created a support case on your behalf - you should receive an email from Customer Support at the email you used to register with the Community forums. Note that we may take a bit long to get back to you since due to recent events affecting our operations, support options are limited and wait times are longer than usual.
