03-13-2021
23:25
07:04
03-13-2021
23:25
07:04
My Versa 2 is currently stuck in a loop between the Fitbit logo screen for 20+ seconds and a black screen for 2 seconds. I’ve tried the factory reset, and I’ve also tried putting the watch back on the charger for 10+ minutes, but nothing changes. The watch just remains stuck in this loop.
Please help
03-14-2021 06:16
03-14-2021 06:16
Odd behaviour -
Probably best to contact Fitbit Support directly. They may be able to help you.
03-15-2021 07:09 - edited 03-25-2024 07:51
Hi there @JND_Versa_2, welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out.
In addition to the steps you've performed so far, please try the following:
If you can't get started with your Versa 2, usually a missing requirement is the cause. Carefully review the requirements provided in the help article: Why can't I set up my Fitbit device?
03-17-2021 10:09
03-17-2021 10:09
03-17-2021 16:01
03-17-2021 16:01
This is me too! I'm stuck on the logo screen but the fitbit isn't connecting to any of my devices that it was connected to before the update.
03-17-2021 22:52
03-17-2021 22:52
@suekitty13 Did you follow the instructions given by @MarreFitbit before positing your issue?
