02-01-2022
02:17
06:32
02-01-2022
02:17
06:32
For some reason my Versa 2, has been draining battery. This time when I charged it, the Fitbit icon on was in the screen and would not change.it.
I tried the factory reset, connected, then failed. Then I started the update and now it’s either frozen or it has died! Not sure what to do.
02-01-2022 06:33
02-01-2022 06:33
Hi there, @Shannon-Versa2. Thanks for stopping by in the Community Forums and sharing the details about the issue with your Versa 2. I understand where your concern is coming from.
If you haven't done so yet, please follow the steps below:
If you can't get started with your Versa 2, usually a missing requirement is the cause. Carefully review the requirements provided in the help article: Why can't I set up my Fitbit device?
Hope that helps.
Best Answer02-06-2022 10:42
02-06-2022 10:42
Thank you for making the suggestions, I had to run out of town for a few days. I attempted to follow your instructions but my Versa won’t even charge now.
So I can not actually do those steps, with now power to the device.
any other suggestions?
