02-01-2022
06:31
11:52
02-01-2022
06:31
11:52
I have tried to do the reset but holding it down and releasing until I see logo. I have done the quick push and than do the same thing. About 2 days ago my watch would just randomly go nuts and start vibrating and would randomly switch screens and than it went black. The light was still working at this point. Yesterday it just like shut off at 1:30 and wouldn’t turn on unless I would hold button down. Problem is I would only get logo never the full screen. Any help is much appreciated
02-01-2022 11:54
02-01-2022 11:54
Hi there, @JenCc33. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2.
It sounds like you've performed a factory reset, that would explain why your Versa 2 is stuck on the Fitbit Logo.
With that being said, I'd recommend trying the steps below:
If you can't get started with your Versa 2, usually a missing requirement is the cause. Carefully review the requirements provided in the help article: Why can't I set up my Fitbit device?
Hope that helps.
02-01-2022 11:54
02-01-2022 11:54
Hope that helps.
02-05-2022 12:05
02-05-2022 12:05
No luck, I think mine is shot
Best Answer02-05-2022 16:02 - edited 02-05-2022 16:03
@JenCc33 at what step mentioned above does the failure occur?
Best Answer02-08-2022 07:38
02-08-2022 07:38
At no point in time does the logo sign go away.
02-14-2022 06:32 - edited 10-30-2023 04:19
@JenCc33 I appreciate you had followed the tips and recommendations provided above.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
