Versa 2 stuck on Fitbit Logo
ANSWERED
My Fitbit won’t sync on the app and the clock face flashes with the logo on for five seconds and then goes black for five seconds. I’ve tried holding down the button as suggested and this has not changed anything.
1 BEST ANSWER
Accepted Solutions
Hi there, @Agosts. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out.
In addition to the steps you've done so far, I'd recommend trying the following:
  • Remove your Versa 2 from your Fitbit account and your phone's Bluetooth settings.
  • Force quit the Fitbit app.
  • Turn off the Bluetooth.
  • Turn on the Bluetooth.
  • Set up your Versa 2 again.
  • If there is no connection, restart your Versa 2.
If you can't get started with your Versa 2, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Hope this helps.
1 REPLY 1
Hope this helps.
