05-09-2022
05:48
10:17
05-09-2022
05:48
10:17
Versa 2 stopped working on May 8th with a dark screen. I thought the battery had run out so I connected it to the charger. After a few hours I saw the Versa 2 was showing the logo and pushed the button to turn it on, but... nothing happened. No error message, no vibration, nothing.
Tried restarting the Versa 2 by pressing the button for 8-10 seconds: still, only shows the logo
Tried a hard reset by pressing the button for 10 seconds and then releasing the button for less than 2 seconds and then pressing it again: still, the Versa 2 only shows the logo.
What happened to the watch? More importantly, how can I fix this? The latest firmware update is on the watch.
05-09-2022 10:19 - edited 12-18-2023 09:25
Hi there, @Woodstock67. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out. I understand where your concern is coming from.
If you haven't done so yet, please follow the steps below:
If you can't get started with your Versa 2, usually a missing requirement is the cause. Carefully review the requirements provided in the help article: Why can't I set up my Fitbit device?
Hope that helps.
Hope that helps.
05-10-2022 05:11
05-10-2022 05:11
Good afternoon,
I followed the steps you laid out:
I could not set up the Versa because BlueTooth could not create a connection to the watch. The watch still only shows only the logo (see the picture).
Is there any way to force the watch to boot and see what is happening? Or to get any kind of error message?
05-10-2022 10:26 - edited 11-03-2023 11:59
@Woodstock67 I appreciate you had followed the tips and recommendations provided above.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
