02-04-2023
09:50
07:01
02-04-2023
09:50
07:01
My Versa 2 is not working. The Fitbit logo is stuck on the screen. I looked up the troubleshooting instructions to resolve this issue also I looked up troubleshooting techniques on this forum, but nothing is helping me with my issue. What can the cause be and how do I fix it? Please assist. Thanks!
Hi @Greg517 - while it could be terminal have you tried the following process?
Hi there, @Greg517. Thanks for stopping by in the Community Forums and trying to troubleshoot the issue with your Versa 2 before reaching out.
Please note the issue you're having comes from performing a factory reset without first unpairing your Fitbit device from your Fitbit account and phone's Bluetooth settings. With that being said and as @Guy_ has suggested, please try the following the steps below in the order listed:
If you can't get started with your Versa 2, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
If you continue having issues updating your Fitbit device, see Why can't I update my Fitbit device?
Hope that helps.
Best AnswerI cannot sync my fitbit. I have restarted both my phone, computer and fitbit 2 times each. I have removed the device and repaired it 2 times. The website also will not update. is there something wrong with fitbit?
