09-22-2023
12:23
08:07
09-22-2023
12:23
08:07
Versa 2 touchscreen stopped working. The reset didn't work. I got a screen with dots in a diamond formation and then the screen goes to black with small letters on the bottom of the screen.
Hi there, @ericmcgill. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Versa 2 and taking the time to troubleshoot it before reaching out.
As per the description of your post, it seems like your Versa 2 is having battery issues. If you've tried charging your Versa 2 for more than 2 hours but to no avail, please make sure you've followed all tips and recommendations provided here Why ins't my FItbit device's battery charging?
If the above doesn't work, connect your Versa 2 to the charger and try the following (while it's connected to the charging cable and even if some of them you've tried already):
With the steps above, what I want you to do is to pair your Versa 2 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
