03-09-2024
07:09
09:50
03-09-2024
07:09
09:50
Versa 2, Phone Ap (iPhone) frozen with white fitbit logo pulsing. Have turned off phone and checked for updates. Any suggestions?
03-09-2024 09:53
03-09-2024 09:53
Hi there, @RFJ13. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Versa 2 is still stuck on the Fitbit logo. I will do my best to help you with this!
In addition to the steps you've done so far, please try the following in the order listed:
With the steps above, what I want you to do is to pair your Versa 2 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
Best Answer03-10-2024 21:31
03-10-2024 21:31
I am having the same issue and tried doing the steps above but the problem is still persisting and now I am not able to pair my Versa2 as the mail actg is still frozen in the logo.
Any suggestions about how to resolve this ?
Best Answer03-11-2024 04:07
03-11-2024 04:07
Hi there, @Sandy26. Welcome on board. I appreciate you taking the time to try the steps I recommended above. I'm sorry to hear they didn't work, I will be glad to continue assisting you!
As our last resort, I'd recommend performing a factory reset. Important: Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account, your applications, alarms, etc.
With the above being said, please follow the steps below to perform the factory reset on your Versa 2:
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
Best Answer03-14-2024 21:30
03-14-2024 21:30
Thanks but it did not worked.
i tried hard reset multiple time but still got stuck on the Fitbit logo and as a result app is also not recognising the Watch .
not sure if anything else can be done to make it work?
I have been facing issues since the last update but the Watch was working albeit with limited battery life. Before the update Watch was all right and working fine with usual 4-5 days battery.
