05-07-2020 13:53
05-07-2020 13:53
HI Everyone,
Just today my Versa 2 stopped syncing with my app? My app keeps saying it is looking for my device but never finds it. Should I delete it and start over? I'm not sure what the problem is. My wifi is fine, my Bluetooth on my phone says the versa 2 is connected? The app and the device are not communicating with each other. I've looked at the help articles but nothing relates. Does anybody have any suggestions? Thank you in advance 🙂
Best Answer05-08-2020 00:28
05-08-2020 00:28
The usual things I try when I get syncing issues are:
If none of those ideas work for you then it’s probably best to contact customer support via: contact.fitbit.com
05-08-2020 00:28
Best Answer05-11-2020 09:54
05-11-2020 09:54
Yes Thank you Steve, I ended up deleting the fitbit and starting over and it worked. Thanks so much for all of the suggestions. Very helpful.
