08-23-2020 08:02
08-23-2020 08:02
In order to sync my Versa 2 I have to open the app and start a sync. If I don't do this the Versa does not sync for days.
For instance today I noticed that the sleep data of last three days were missing.
Is there a way to sync the device automatically, at least once a day?
08-23-2020 10:15
08-23-2020 10:15
If by "have to open the app" you mean that you have not only closed the app but taken it out of memory instead of placing it in the background... that is the problem.
The app needs to be running to for the device to sync. Foreground or background, it doesn't matter, it just needs to be there for the device to communicate with.
10-22-2020 07:38
10-22-2020 07:38
10-22-2020 23:57
10-22-2020 23:57
If I don't scroll the display from top to bottom with the Fitbit app, it does not sync. Never, even after days, even with the app opened in foreground, I don't see the sleep info, the battery status, etc.
Previously I had a Mi Band 2 and I was able to see all the info on my phone without any manual operation. How it is possible that a 5 time more expensive device need to be sync manually???
11-19-2020 07:07
11-19-2020 07:07
I have to do the same thing, its very frustrating. A month ago I was not having this problem
Best Answer11-19-2020 07:09
11-19-2020 07:09
I have been having the same issue over the last month. I keep the app opened in the background on my phone but I still have to go to the app and refresh for it to sync
11-19-2020 08:02
11-19-2020 08:02
Still the same problem here.
If I don't sync manually, I don't have any data, so when I don't sync the device for three days I don't see the last three days info on the app.
Moreover it is also quite difficult to sync manually and sometimes I need to repeat the operation several times.
For instance, today is Thursday, I have opened the Fitbit app (not in background) from several hours but the last data I have stored go back to the last Sunday when I manually synchronized my Fitbit Versa 2.
I have sadly to say that with my old $25 Mi band 2 I never had this kind of problems.
Best Answer12-02-2020 22:41
12-02-2020 22:41
I just figured it out on my device! Hope this works for you. Go to Android settings and go to Adaptive Battery (if you can't find it, search it) and turn it off. Adaptive battery kills apps it doesn't think you're using much. There's probably a way to whitelist the app, but that was an immediate fix for me. Good luck
Best Answer12-02-2020 23:10
12-02-2020 23:10
Spoke too soon, still happening. At least the Alexa app is working on the watch now
