03-18-2023
20:51
07:06
03-18-2023
20:51
07:06
Last week my Versa 2 touch screen stopped working. I have restarted it many times and changed the clock face. It is up to date, battery is fully charged etc. Any suggestions?
03-23-2023 07:11 - edited 03-24-2023 09:57
Hi there, @Celsam. Welcome to the forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out.
To better assist you, please make sure you've restarted your Fitbit device as suggested here How do I restart my Fitbit device?. If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
If the above doesn't work, as our last resort, I'd suggest performing a factory reset by following the steps below (please make sure that your Versa 2 is no longer paired to your phone's Bluetooth before performing this step):
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
Best Answer03-23-2023 07:11 - edited 03-24-2023 09:57
Best Answer04-21-2023 03:43
04-21-2023 03:43
I have tried this and my Fit Bit versa 2 touch screen is still not working. The watch is only just over a year old.
