10-05-2021
05:29
07:23
10-05-2021
05:29
07:23
Even while driving for a minute, versa 2 is showing 10k steps for the 3rd time today. Never faced this issue before. Been using this watch for 1 month.
10-05-2021 07:24 - edited 03-03-2024 03:32
Hi there, @Yumna. Welcome to the Community Forums. Thanks for the details provided in your post. I understand where your concern is coming from.
Please not wrist trackers count steps depending on the movement of your arms. Fitbit has worked hard to make sure that our devices do not pick up false steps or activity recordings while driving. Unless you're driving in a car with a very stiff transmission or on bumpy roads, your device should not give you false readings. Also, if you place it in a surface with something vibrating or if you make hard hand movements. You can learn more about how your Fitbit tracks steps by checking the article: How accurate are Fitbit devices?
However, there are 2 ways you can prevent this from happening while you drive:
1. You can plug your tracker into the charging cable while you are driving -- the Fitbit will not count steps while it is charging.
2. You can log the driving manually by following the steps in this article.
Hope that helps.
Hope that helps.
10-05-2021 09:17
10-05-2021 09:17
