Okay, let me try to get the answer I've searched in vain for. I get it that Versa comes with two strap sizes, short and long. I get it that a Versa 2 strap is incompatible with a Versa 3 because a Versa 2 strap attaches directly to the watch, while a Versa 3 strap attaches using an adapter.
A Versa 3 uses any 20mm strap, which fits into the adapter just as it would on a conventional watch with 20mm lugs.
Here's the question that seems to go unanswered: How wide is the strap for a Versa 2, measured in millimeters, where it attaches to the watch, and will it fit the Versa 3's adapters? I ask because I have a goofy wrist and there are Versa 2 straps that would work perfectly for me if that fit my Versa 3.
Thanks in advance for any good advice.
