08-02-2022 21:36
08-02-2022 21:36
After updating my Fitbit versa 2, the watch no longer swipes up. it is a blank screen and no stats show up. I tried setting a new clock face with no luck. help!
08-03-2022 09:35
08-03-2022 09:35
Hello again @valerieann423
I suppose it wouldn’t hurt trying to set your Versa 2 up again as a new device. You won’t lose any data. The only data you will lose is anything that occurred “after” your last successful sync. Here’s how if you want to try:
Let’s try these steps: (again, you will not losing any data setting your Versa 2 as a new device but it only saves data from your last successful sync)
08-03-2022 05:08
08-03-2022 05:08
Hello @valerieann423
I’d try restarting your Versa 2 by holding down the button on your Versa 2 until you see the Fitbit Logo then release the button. You should feel your Versa 2 vibrate indicating it has finished the restart. Hopefully that will fix the issue.
😃 Let me know how it goes
08-03-2022 08:48
08-03-2022 08:48
Unfortunately, i tried that several times and tried changing the clock face with no luck. The fitbit is brand new and after i did the update doesn’t work properly which is so frustrating.
Best Answer08-03-2022 09:35
08-03-2022 09:35
08-03-2022 12:32
08-03-2022 12:32
girlll you are my hero!! many thanks to you. you fixed my problem and i couldn't be more grateful!
08-03-2022 12:42
08-03-2022 12:42
That’s fantastic news @valerieann423! 😃 I’m happy I was able to help. I hope you have an awesome rest of your day and as always Happy Stepping!
Best Answer03-06-2023 11:48
03-06-2023 11:48
Thank you! it fixed the problem
