11-16-2021
15:08
05:39
11-16-2021
15:08
05:39
My Versa 2 ticks when i charge it, this just started. It also has the logo on the screen and i cant get back to the setting screen. I tried the reset with no luck.
Any one have any suggestions?
Thanks!
11-17-2021 05:43 - edited 02-24-2024 02:28
Hi there, @BillTacoma. Thanks for stopping by in the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out.
If you haven't done so yet, please follow the troubleshooting steps provided in this help article Why isn't my Fitbit device's battery charging?
If your Versa 2 keeps stuck on the Fitbit logo even after being fully charged, please try the steps below:
If you can't get started with your Versa 2, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Best Answer11-19-2021 06:11
11-19-2021 06:11
Hello,
I disconnected the fitbit from blue tooth, forced quit, shut off the phone and now the fitbit wont even respond. I tried to charge it and nothing. i tried a few different times with no luck
Thanks
Bill
Best Answer11-19-2021 09:47 - edited 02-24-2024 02:00
@BillTacoma I appreciate you had followed the tips and recommendations provided above.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
Best Answer11-19-2021 11:35
11-19-2021 11:35
Hi Bill. I woke up yesterday to my Versa 2 doing the same thing. I tried all the suggestions here and on YouTube, no luck. I just got off the phone with Customer Support (in India, I believe). He briefly instructed me to do everything I had already tried. He was then quick to tell me that I would be receiving an email from customer service. I received the email with a 35% discount to buy a new one. Since this is my second Fitbit in 3 years, I’ll be buying another brand 🍎. Good luck!
Best Answer11-20-2021 04:01
11-20-2021 04:01
Hi boston sue!
How soon after the call did you get the email? im still waiting for mine. I feel you there! this fit bit is 3 months old!
Best Answer11-20-2021 05:36
11-20-2021 05:36
I received the first email within a minute or 2, after hanging up with the guy from India. The email basically said “sorry your Fitbit is out of our warranty period” and that another email would follow, with a discount code. The second email came immediately after. My Fitbit was just over a year old, but they should last longer than that! If yours is only 3 months, I would think they would replace it. 🤷🏼:female_sign:
