02-17-2023
15:03
04:58
02-17-2023
15:03
04:58
Hi, when charging my Versa 2 it charges quite quickly until it gets to 99%, then takes 90 minutes to get to 100%. Is this normal?
To me, that just means that you are putting a lot of unnecessary extra stress on the battery, shortening its life, so you can see 100% instead of 99%. Lithium-ion batteries supposedly last longer if you try to keep the charge between about 20 and 80%. Very low and very high charge puts added stress on battery.
Thank you for that information, of which I wasn’t aware to be honest. Do you know if these Fitbit batteries can be replaced?
Hi there, @Davess33. Thanks for stopping by in the Community Forums.
In addition to @JohnnyRow's suggestion about keeping the charge between 20%-80%, please see the following tips for charging your Versa 2:
As for your inquiry, note that the battery on your Versa 2 is not replaceable nor interchanged. We as Fitbit do not do it or suggest to do it as it could permanently damage your watch.
