11-16-2022
07:39
09:34
AndreaFitbit
11-16-2022
07:39
09:34
AndreaFitbit
Hello,
my versa 2 was low battery when I got it wet. After that the battery died and won’t charge.
still shows low battery with exclamation on the screen.
I cleaned, try the reset button, dried , waited hours. Nothing works.
someone can help ?
Moderator edit: format.
Thanks for getting back to us and for following advised troubleshooting steps @camirh91.
I understand how frustrating this could be and went ahead and created a case on your behalf and a customer support representative will contact you soon.
See you around.
Welcome to the Fitbit Community, @camirh91. I'm sorry to hear your Versa 2 battery isn't charging and thank you for mentioning the steps you have followed in order to charge it again.
Please confirm that you have followed these steps:
Made sure you used the charging cable that came with your device, as most cables aren't compatible with other devices.
Check the alignment and try reconnecting your device to the charging cable. For more information, see How do I charge my Fitbit device?
See you around.
See you around.
