07-10-2021
07:12
08:21
07-10-2021
07:12
08:21
Trying to charge Versa 2 and suddenly I get a message that says "Not enough power from source"
I have tried several different blocks, outlets, etc. nothing. . . this is barely a year old....never had trouble of any kind. Any suggestions? I have cleaned the contacts with alcohol. . . .
07-10-2021 08:28
07-10-2021 08:28
Hi there, @lmhampton61. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out. I understand where your concern is coming from.
As a first approach, I'd recommend restarting your Versa 2. For more information, see How do I restart my Fitbit device?
If your watch doesn't vibrate when trying to perform the restart, please try the steps below:
If the above steps don't work, I'd suggest performing a restart by following the steps below (please remove your Versa 2 from your phone's Bluetooth before performing this step):
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
Hope that helps.
07-10-2021 08:28
07-10-2021 08:28
Hope that helps.
07-10-2021 09:19
07-10-2021 09:19
07-10-2021 10:04
07-10-2021 10:04
I am having the exact same problem as you! I tried all those same steps without any success . My fitbit versa is also about a year old. It is a shame because I loved using my fitbit!
07-10-2021 12:45
07-10-2021 12:45
07-11-2021 19:32 - edited 11-19-2023 03:37
@lmhampton61 @Getfitbrit.993 We‘re taking into consideration your comments and sentiments in regards to our products and services. I appreciate you had followed the tips and recommendations provided above.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
07-12-2022 10:47
07-12-2022 10:47
Agree!! Same for me. My last 2 fitbits also crapped out just after the 1 year warranty was up. Also the Fitbit pay options in Canada are pitiful. Think I’ll be switching to Apple Watch also.
