07-07-2022
16:14
06:48
07-07-2022
16:14
06:48
I'm thinking my daughter's Versa 2 has died. It seems to have stopped working a couple of weeks ago, but I want to get it back up and working.
We have tried charging it, tried restarting it, tried different clock faces, to no avail. While restarting, nothing happens. The Fitbit logo never comes on after holding the button for well over 10 seconds. While it gets placed in the cradle to charge, the screen will turn a light green after a few seconds and sometimes flickers a little and it turns back to black eventually. Tried changing the clock face as others suggested, but doesn't seem to be able to connect with the Fitbit, so that doesn't work at all. Tried logging out of the phone app, and relogging back in. Nothing. It can't seem to connect to wifi at all since it's not searchable. I'm just not sure what, if anything, can be done. Am I pretty much SOL? She's had it for 2 years. I'm wondering if that's the life span of this expensive watch. Really frustrated as I've had good luck with all my previous Fitbit watches, which is why I got her one. Are there any tried and true secrets out there that will fix this??? Is there a little battery in there that can be replaced at all?
07-08-2022 06:50 - edited 11-16-2023 10:45
Hi there, @hrgdane. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your daughter's Versa 2. We‘re taking your comments and sentiments in regards to our products and services into consideration.
I've seen you contacted our Support Team after posting here and they've already assisted you. If you still need help or have any questions/concerns regarding the outcome of your case, please feel free to contact our team back for further assistance.
See you around.
Best Answer07-09-2022 06:48
07-09-2022 06:48
Was there any resolution through tech support, or are you out of luck? I've tried everything you have, but my screen remains black even when on charger. My versa 2 is about 2 years old as well.
Thanks!
Best Answer07-09-2022 14:52
07-09-2022 14:52
