03-25-2021
07:08
14:53
03-25-2021
07:08
14:53
My Versa 2 stopped working while on the charger one evening. I've checked that the charger is working properly (it is) I've also tried to reset the Versa 2 by holding down the button for 10 seconds. Nothing works. I've reloaded my Fit Bit app, tried to sync it, nothing. The screen has the Fitbit symbol show up occasionally but that is all it will do. Please help! I love this thing and swear by it everyday.
03-25-2021 14:53 - edited 09-12-2023 09:04
Hey there, @ESchwartz0312. Thanks for sharing the details about the issue with your watch and trying to fix it prior posting here. Since your watch is getting hot, please note the best way to get help for this problem is to chat with us online or give us a call. Click here to get connected. We hope your issue is solved soon.
Hi there, @versa2problems. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out. I understand how yo must be feeling.
In addition to the steps you've tried so far, I'd recommend following the troubleshooting steps provided at Why isn't my Fitbit device's battery charging?
As for the Fitbit Logo, please try the below steps once you've tried the above suggestions:
If you can't get started with your Versa 2, usually a missing requirement is the cause. Carefully review the requirements provided in the help article: Why can't I set up my Fitbit device?
03-25-2021 09:56
03-25-2021 09:56
This happened to me today while on my 8 mile run. Just quit at mile 5. It will not charge. It will not sync and I can occasionally hold down the button and get the Fitbit symbol to show up. Then nothing. It also feels extremely hot.
