03-30-2021
20:28
05:15
03-30-2021
20:28
05:15
Hi. I normally wear my Fitbit Versa 2 overnight whilst sleeping. Two Thursday's ago, it died overnight. I plugged it in to charge in the morning and left it whilst doing some things. Ever since, it will not turn on. The screen remains black regardless if I hold down the button or not. There have been approximately 3 times where I first plug it in to charge and the screen works (but only when still charging). This is only for a short period of time. The device is less than 12 months old.
Hi there, @emmaabradleyy. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out.
If you haven't done so yet, please restart your Versa 2. For instructions, see How do I restart my Fitbit device?
If the restart doesn't work and your watch has not vibrated when you connected it to the charger, try these steps:
If the above doesn't make any change on your watch's behavior, I recommend doing a factory reset. Before doing so, make sure to remove your watch from your Fitbit account, then follow the steps below:
You can now set up your Versa 2. For instructions, see How do I set up my Fitbit device?
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account, your applications, alarms, etc.
