05-28-2021
01:20
04:33
05-28-2021
01:20
04:33
My versa 2 gets stuck on screens, the side button doesn't work, and it's not tracking my sleep correctly. It won't even reset with fitbits instructions on resetting. PLEASE HELP!
05-29-2021 04:35 - edited 04-07-2024 06:42
Hi there, @SunsetRunner. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out. I understand where your concern is coming from.
Since the restart hasn't worked, try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Regarding your sleep data, if you are not receiving sleep stages, I recommend considering the following:
For more information, see What should I know about Fitbit sleep stages?
05-28-2021 04:39
05-28-2021 04:39
Are you able to get to settings on the watch and do About and then Shutdown?
Also if it is syncing ok, consider changing the selected clock face in case the current one is blocking things..
Putting it on the charger or pushing the button should wake it, but it is a risk it might not.
