08-24-2021
16:46
04:00
08-24-2021
16:46
04:00
Can i please get help, i have an issue with versa 2 just randomly disconnecting, all updates are done, i have compatible phone too on android. Only other bluetooth i use is for my hearing aids, so really cannot disconnect them. Will this keep happening.?I have only just updated from charge 3 to versa 2 and i love it, but need something that can handle multiple bluetooths.
08-25-2021 04:08 - edited 08-28-2023 09:21
Hi there, @Sunspot76. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 2. I understand where your concern is coming from and how important is to you to keep your hearing aids connected to your phone.
You've mentioned that your Android phone is a compatible device; but, May I know the model of your mobile phone? Please make sure it meets the requirements listed here.
In addition, please take the following requirements into consideration:
If you continue having issues after checking the above, let's try the following troubleshooting steps:
Best Answer08-25-2021 04:08 - edited 08-28-2023 09:21
