01-19-2024
00:46
02:57
01-19-2024
00:46
02:57
Hi my versa 2 will not connect to bluetooth, I have tried resetting phone and watch, even removing app and reinstalling, but having trouble staying connected, it will connect for a short period of time following a reset and then just loose connectivity, Bluetooth on phone is ok as I have other things that's stay connected. This has only happened since I upgraded my phone.
01-19-2024 23:30
01-20-2024 03:03
01-20-2024 03:03
Hi there, @RAW1976. Welcome to the Fitbit Community Forums. Thanks for taking the time to troubleshoot the connectivity issues with your Versa 2 before reaching out, I understand where your concern is coming from. I'll be glad to help you!
If you haven't done so yet, I'd recommend the following steps in the order listed:
With the steps above, what I want you to do is to pair your Versa 2 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
@Guy_ Thanks for stopping by and your input!
Best Answer01-20-2024 23:31
01-20-2024 23:31
