09-24-2025
20:29
04:17
09-24-2025
20:29
04:17
I cannot sync tried everything. Phone is compatible Get a code then a error message.Not been working for a week was working before. Green light on charger doesn’t come on when connecting?
09-25-2025 04:23
09-25-2025 04:23
Hi there, @YoIngoa. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Versa 2 stopped syncing. I understand your concern, I will do my best to help you with this!
To better assist you, please confirm that you've tried all troubleshooting steps provided in this help article Why won't my Fitbit device sync?
If the above doesn't work and since you mentioned that you're getting a code and then an error message, I'd like you to please confirm that your Versa 2 is still paired to your Fitbit account. To do so, from the Today tab, tap Devices > device image. If you no longer see your Versa 2 as a paired device, please see How do I set up my Fitbit device?
Best Answer09-26-2025 01:28
09-26-2025 01:28
Best Answer09-26-2025 04:19 - edited 09-26-2025 04:19
@YoIngoa Thanks for getting back to me and for the update. I appreciate you for trying all the steps I recommended.
In addition to what you've tried, please try the following steps in the order listed:
If you can't get started with your Versa 2, usually a missing requirement is the cause. Carefully review the requirements provided in the help article: Why can't I set up my Fitbit device?
