09-13-2021
09:17
09:19
BraulioFitbit
09-13-2021
09:17
09:19
BraulioFitbit
Since yesterday, I cannot get my versa2 to sync to the app. I've turned Bluetooth off and back on, uninstalled and reinstalled the app, tried force stopping the app, nothing has worked. App is up to date, android version is current. What am I missing?
09-13-2021 09:28
09-13-2021 09:28
Welcome, @Marie41210. It's great to see you around.
Thanks for the details about the syncing difficulty and for trying some troubleshooting steps before posting here. You can try the troubleshooting tips listed on this help article: Why won't my Fitbit device sync?. In case that your Versa 2 is still not syncing, you can try to set it up like a new device as instructed here.
By the way, I moved your post to the Versa 2 board to keep our forum organized and you can also receive assistance from other Versa 2 users.
Hope this helps.
09-13-2021 17:39
09-13-2021 17:39
This did not work. I removed the device, and now it just says there is no device to connect to. I'm really frustrated at this point
09-13-2021 19:57
09-13-2021 19:57
This has just happened to me.
Best Answer09-13-2021 20:09
09-13-2021 20:09
Same. Removed the device after some other troubleshooting with the online chat advice, and now nada. Device no longer available for connection. FitBit offered me a discount on a new FitBit to replace the Versa 2 (which was a replacement for the Versa) but now I'm worried that the Versa 2 has too many problems if there are others also having issues with Versa 2 ...
09-13-2021 20:25
09-13-2021 20:25
09-14-2021 01:25
09-14-2021 01:25
Same with me seems like after I got the IPhone 12 it’s not syncing correctly.
