02-18-2023
09:10
12:18
02-18-2023
09:10
12:18
My versa 2 has been giving me many issues lately. The “today” app will not work on my watch. I try to open it, it loads for a second or two and then crashes. My watch is also 6 minutes slow now and I can’t fix it. Resetting the watch, removing and re-adding the watch into the app and deleting and re-installing the fitbit app all do nothing. Any suggestions?
02-18-2023 12:20 - edited 03-09-2024 07:46
Hi there, @NoahDavidson. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 2.
As @Guy_ has mentioned, your Fitbit device may show an incorrect time if it hasn't synced or has been unpaired from your Fitbit account. Your Fitbit device uses the time of the device you're syncing with. If the restart he suggested doesn't work, please try the following steps:
02-18-2023 10:41
02-18-2023 10:41
HI @NoahDavidson - the watch has to sync well for the time to be set right. You could try changing clock face but it may be an inherent problem, that maybe not even a factory reset will fix.
You can chat via the Fitbit App, click profile photo, Help & Support, Contact Customer Support, for them to help you with that.
