10-10-2020
01:24
14:52
10-10-2020
01:24
14:52
I Fitbit will not light up. Sometimes while I am wearing my watch I can not get it to wake up. It was not show anything. If I touch the buttons on side nothing happens. Its basically like I have a bracelet not a watch.
10-12-2020 14:55 - edited 10-11-2023 03:19
Hi there @Rakelle717, welcome to the Community Forums. I'm sorry to hear that your Versa 2 isn't turning on, I understand where your concern is coming from and how you must be feeling.
I'd recommend restarting your Versa 2 by following these steps: How do I restart my Fitbit device?
If your Versa 2 has not vibrated when performing the restart, please try the steps below:
If the above steps don't work, at this point I recommend doing a factory reset (before doing so, make sure to remove your watch from your Fitbit account):
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account, your applications, alarms, etc.
Best Answer10-12-2020 14:55 - edited 10-11-2023 03:19
