08-20-2020
11:06
11:40
08-20-2020
11:06
11:40
My Versa 2 went dead after I forgot my charger on vacation. I returned home and it will not turn on despite multiple attempts to charge. Screen is black no matter what I do. Have changed outlets, USB chargers (the block thing that plugs into wall, I am only using original Versa 2 charger). I have held button down for ten seconds multiple times. I have cleaned charging ports with rubbing alcohol. Nothing works. This Versa 2 is only a few months old and I had a similar issue with my Versa that was over a year old.
08-21-2020 11:44 - edited 02-26-2024 09:03
Hi there @snitchy4025pm, welcome to the Community Forums. Thanks for the details provided in your post about your Versa 2's recent behavior. I appreciate you've already taken the time to troubleshoot your watch prior to posting here, I'll be glad to help you with this.
While reading your post I was wondering if your Versa 2 vibrates when you connect it to the charger? If it's not, please confirm if you tried the steps below:
If the above steps don't work, I'd suggest performing a restart by following the steps below:
Take in consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
I'll be waiting for your reply if further assistance is needed.
Best Answer08-21-2020 12:00
08-21-2020 12:00
Best Answer08-21-2020 14:02
08-21-2020 14:02
Hi there @snitchy4025pm, thanks for getting back and for the update. I appreciate you had followed the tips and recommendations provided above. Since this sounds a bit more serious, I've created a support case on your behalf - you should receive an email from Customer Support at the email you used to register with the Community forums. Note that we may take a bit long to get back to you since due to recent events affecting our operations, support options are limited and wait times are longer than usual. If you have any questions, don't hesitate to let me know.
