Versa 2 won't turn on
ANSWERED
Hello,
  • As the title says, my versa 3 dfreenbis no longer working. It had been turning white with some lines of colour through it for the last few weeks but now has stopped working completely. I tried reseting with the button o the watch, disconnecting Bluetooth and all other recommendations but the issue is still there. The watch is less than 2 years so still under warranty
1 BEST ANSWER
Accepted Solutions
Hi there, @ekelly1987. Welcome to the Fitbit Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out.
To better assist you, please make sure you've restarted your Fitbit device as suggested here How do I restart my Fitbit device?
If the restart doesn't work and the Versa 2 does not vibrate while trying to perform the restart, I'd suggest making sure you've also tried all steps provided below:
  • Clean the charging contacts on the back of your device and the pins on your charging cable using the instructions in How do I clean my Fitbit device?
  • If the error "insufficient power source" appears on your device's screen, remove other devices plugged in to your power source, or plug your device in to another source.
  • Try a different USB port or a UL-certified wall charger.
  • Check the alignment and try reconnecting your device to the charging cable. For more information, see How do I charge my Fitbit device?
  • Restart your Fitbit once again. For more information, see How do I restart my Fitbit device?
If the above steps don't work, I'd suggest performing a restart by following the steps below (please remove the Versa 2 from the phone's Bluetooth before performing this step):
  1. Hold the back button for about 8 seconds.
  2. When the Fitbit logo disappears:
    1. Release the button briefly (for less than 2 seconds).
    2. Hold the button again until you feel a second, longer vibration, which indicates you initiated the factory reset.
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
2 REPLIES 2
I have attempted all of the above and the screen is stil not working
