10-19-2024
00:51
06:52
FatimaFitbit
10-19-2024
00:51
06:52
FatimaFitbit
How can I get my versa 3 to work . It won't let me add it to my devices.
10-23-2024 06:55 - edited 10-23-2024 06:55
Hi there @Murdan! Welcome to the Fitbit Community! It's great to have you here!
Can you see something on the display of your Versa 3?
I suggest you try to do this:
Best Answer11-03-2024 10:32
11-03-2024 10:32
I'm having the same issue. Charge went really quickly one day and then it can no longer charge. Things I have tried are:
It seems that it can turn on, but not actually charge. Before I reset it, it was struggling to connect via Bluetooth to my phone. Since I reset it, it won't connect for me to set it up. I try to set it up but the app doesn't recognise it and says it's looking for the device to connect.
The back green lights aren't on and don't flash either. Says batter is too low to connect on the app.
When left on the charger, the screen will come up (the one saying to set up the device), but after a while it just turns itself off.
Best Answer11-05-2024 08:07 - edited 11-05-2024 08:07
Best Answer11-05-2024 14:34
11-05-2024 14:34
No, it won't connect to my phone via Bluetooth as the 'battery is too low'.
