10-28-2024
15:47
12:19
AndreaFitbit
10-28-2024
15:47
12:19
AndreaFitbit
Hi
any one still using versa 2 ?
recently my versa 2 constantly drops connection with phone
any one else have this problem
Moderator Edit: Clarified subject.
10-28-2024 18:07
10-28-2024 18:07
Yes. My versa 2 has not dynched with my fit phone app for at least 2 days. There is a reported issue with synching some androids at this time. I was told to wait another 3 or 4 days for a fix.
10-29-2024 12:35 - edited 10-29-2024 13:39
Welcome to the Fitbit Community, @Paul_65, thanks for getting back to us @Pacamoma. I'm sorry to hear that you haven't been able to sync your Versa 2.
As @Pacamoma mentioned, we’re currently investigating a syncing issue affecting some Android users.
I apologize for the bug and recommend that you upgrade to the FitBit App version 4.28.2 since it includes a Bug Fix.
Please let me know how it goes.
Best Answer10-29-2024 15:49
10-29-2024 15:49
thanks for quick reply, I've been an avid user of my versa since given it as Xmas present. but my specific issue is not just syncing , my gps connection keeps dropping and I cannot see my run routes also it now also will not sync with strava . will the new fix solve these problems?
18:36
10:18
AndreaFitbit
10-29-2024
18:36
10:18
AndreaFitbit
Today I seem to be having same issue won't sync to iphone. When I deleted trying to sync Iphone can;t locate Versa where it used to just ask if switched on or nearby. Is this the same issue?
1 hour trying but finally updated. all good thanks
Best Answer10-30-2024 10:30
10-30-2024 10:30
Thanks for getting back to us and for the clarification @Paul_65. Were you able to update your Versa 2 to the firmware version: 4.28.2? The bug fixes are mainly for syncing and pairing issues. I can add to the report what you mention if it's still happening with this version.
@DJPFB, I'm glad to hear that you were able to update and all is good now.
Best Answer10-31-2024 11:01
10-31-2024 11:01
My issue with my Versa 2 is that I can sync to the app, but my watch says I've done 4.27 miles, but the app says 3.77, but yet the number of steps remains the same. I've been having this issue for weeks now. Some days it's fine, others it's just totally wrong. It seemed fine yesterday but after the latest update not so much.
Best Answer10-31-2024 13:58
10-31-2024 13:58
I've updated to the version you called out 4.28.2 and still haven't been able to sync. I've done all the recommended suggestions to no avail.
Best Answer11-05-2024 14:43
11-05-2024 14:43
I updated my Versa 2 with the 4.28.3 update from Google Play store on 11/1 and it has been working fine, so far.
11-05-2024 14:52
11-05-2024 14:52
I've updated from play store but gps still lkgs out whilst running and although all my running stats are available, my route is not ,any ideas how to fix this ?
Best Answer11-05-2024 23:38
11-05-2024 23:38
Pleased yours is working, no luck still with mine, 2 weeks and counting 😞
Best Answer11-06-2024 06:32
11-06-2024 06:32
Hello. I have not been able to connect my fitbit versa 2 to my Samsung phone for at least 2 weeks. I have un-installed and reinstalled the app, restarted both devices and have app version 4.28.3
Is there supposed to be a fix out? I use it mainly for text and call alerts and have missed important work calls due to this issue. Thanks.
